Confused over which amp and speakers to get :S
Hi, I'm looking to get some speakers and an amp to play music from my laptop.
I have a budget of £200 max (preferably lower though)
The sort of music I listen to is Bjork, Crystal Castles, The Knife, M.I.A
In the future I'd also like to purchase a vinyl player so an amp that could play with one of those would be good. I had a look at some other posts and saw the Nad C320BEE looks good (and affordable second hand :p)
If you need my system specs I will post then.
So any suggestions of amps or speakers would be really good,
Thanks in advance
Hi
For your budget s/hand is only real viable route. I would discourage Nad, purely because they don't have an in-built phono stage for a turntable.
To that end I'd look at Rotel RA-01, Arcam Alpha 7R and these should accommodate your laptop. Speakers for Rotel would be B&W 601, Wharfedale 9.1. For the Arcam I would look at Wharfedales again and Monitor Audio RS1s.
