- Aug 10, 2019
- 2,556
- 5
- 0
I recently changed the audio hifi cables (small thin bits of wire originally supplied with the units many years ago) for my CD player (Marantz) , Tuner (Denon) and Amp (Denon) for Atlas Equator MkII cables and both my wife and I were impressed with the results (blind testing) and thought we would upgrade the sound surround interconnect cables. Fool that I am I ordered QED Qunex P-CV1 cables (very cheap at £15 which arrive tomorrow,too late to cancel) instead of a composite cable with an audio pair (i.e. Yellow, Red and White). However to try and rescue the situation I can not see that there is much difference in specification between a composite and component video cable (what is the difference? is a component cable just 3 composite cables stuck together with different colour codes?).
So
1. Can I use 1 strand of the component cable for composite, or is a true composite cable a better performer?
2. Can I use all the component cables for the audio/video (R,B,Y) and it will be just as good using any other type of composite/auido cable combination
3. Finally, am I wasting my time? Would the original bits of cable that came with the devices be just as good (I will blind test and let you know)?
I am mainly using the cables for 2 systems (Onkyo 605 to Humax and VCR (so 2 sets of cables) and Onkyo 876 to another Humax. I have noticed that I could use optical cable for some of the audio connections which would be even better, but leaving that aside i am interested in your views on the above.
Thanks for any information, all helps understanding!
So
