codes for itv 1hd
daveh75
mgillespie05:hi guys just had my hd box replaced ,so i need to redo my itvhd I assume you're not in England/Wales so can't access it on the EPG?
There's two FTA versions you can add, as follows...
ITV1 HD London
Frequency: 10.832 GHz
Polarization: Horizontal
Symbol Rate: 22.0
FEC: 5/6
Note- only 1440 x 1080.
ITV1 HD Granada
Freqeuncy: 10.936 GHz
Polarization: Vertical
Symbol Rate: 22.0
FEC: 5/6
1920 x 1080i resolution
and why is it that when they change your box they cant copy your content
There is no facility to copy data from one box to another.
The only way it's possible, is to remove both HDDs and connecting them to a PC,then using third party software called copy+ to copy the data from the old drive to the new.
