co-axial cable help
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=usb&ModuleNo=275&C=SO&U=Strat15
Thanks Folkie, only question is; looks abit cheap? I already have a 'standard' cable just wondered if a high-premium priced one would word better?
That old chestnut. Well, without wanting to start another discussion on the merits of digital cables, have a look at some of the cables rated here by WHF and then get them from somewhere which will allow you to trial the cable for a period and send it back if you're not happy with it - if you don't think a premium cable is worth it, you then have the option to send it back for a refund.
Personally, I use a Chord Codac Silver Plus and am perfectly happy with the performance.
james9002uk:I'm guessing its the same story as with the HDMI cables as is with the coaxial ones? Up to the individual to decide.
That's always the safest place to leave it
james9002uk:Thanks Professorhat, I was looking at the http://whathifi.com/Review/Supra-AnCo-coaxial/ Im guessing its the same story as with the HDMI cables as is with the coaxial ones? Up to the individual to decide.Just to clarify what are you going to be using this cable for! Because from your other thread i assumed it was for an aerial fly-lead but the lead you linked to is an audio interconnect.
Ahhh sorry to confuse you both, its for an aerial cable from sat to my bt vision and tv. Would this make a difference in signal and picture quallity at all or not?
