cleaning partington super dreadnoughts with what?
I tried to give my silver/steel partington super dreadnoughts a clean the other day but they now look grey? :doh:
does anyone know what cleaner would be best to get them looking new again?
cheers!
yep.. i used AutoglymPaint Renovator..:wall: and then tried to buff them up with Autoglym Super Resin Polish which has resulted in them being a gun metal grey colour...
on the upside they are totally scratch free now..:grin:
Sizzers
188
Personally I would have used Autosol.
A truly amazing metal polish but I have no idea how/if it may restore your stands, but 6 quid for a tube in Halfords.
Edit: Are they just natural silver steel or silver painted?
CnoEvil
556
11
If the paint Renovator is like T-Cut, it removes a layer of paint, which is OK on a car, but may have removed too much from your stands. I could be wrong (I hope I am), but you may have done irretrievable damage....give Partington a ring (if that's possible).
Your other option is to have them re-sprayed....sounds drastic, but I had a friend re-spray some old tatty Atacama stands with matt black from a tin and it worked a treat.
What ever you do, tread carefully, and at the end of the day, it might be safer to live with them.
thanks for the advise guys, i decided not to muck about with cleaning products,
i have primed them up with some black prima and then i will spray them gloss black, even with the prima on they look a hundred times better..
should of done it ages ago...
CnoEvil
556
11
Matt Black can often look better...not that I'm telling you what to do or anything. :shifty:
CJSF
251
I'd use a black satin finish, we used satin on all our stands. Gloss always looks a bit 'in your face to me'?
CJSF
your both right gloss would be a bit in your face, i will swap the cans over tomorrow for some Mat black, i like the way they look with the mat primer..cheers chaps
I decided to go for a black satin finish in the end, just to give them a little sheen..
here they are before i bodged them up trying to clean them, they were scratched and had some light chips to the paintwork.
and after using a rust mat primer and 4 coats of black satin spray..
I am very happy with the results.
Thanks to everyone for your advise, i so much prefer them in black.
:cheers:
yes they are, i am really pleased with the way they have turned out..
