Cleaning LCDs....
I recently bought the Panasonic TX-32LXD700 and I am delighted with it! I was just wondering if anyone would recommend a decent cleaning cloth or cleaner to use on the panel? Or would a standard duster be fine if wiped with care?
Any suggestions would be very welcome!
Saundinho
You should have got the ideal cloth with it - if not, any microfibre cloth will do a great job
Nope, I definitely didn't get a cloth with my LCD. I will look to get a microfibre cloth to keep it dust-free then!
Thanks for your response!
