Chord SilverScreen and KEF 3005 speakers
Hi
Does anyone know if these cables will fit or are they too chunky? Also, if I'm not wall-mounting I should be able to use banana clips right?
Many thanks for any advice you can give!
M
These are banana clips. Is this what you mean? The Chord cable is recommended for longer runs in home cinema so it should be ok if you have spring clips on the Kef speakers
You will be able to use this cable as you can trim the ends to reveal the inner cores. Plugs might be a bit bulky at the speaker end though, we generally only use tehm at the amp end on the 3005.
