Does anyone know if the Chord Rumour 2 is a significant improvement over the Carnival Silverscreen? The description for the Rumour 2 is that it uses silver-plated oxygen free copper. Does this mean that it will tend to sound bright and maybe not match components like the Cambridge Audio 650 range? Should I stick to the Carnival Silverscreen as the Rumour 2 is about twice the price of the Carnival Silverscreen?
Which ever I go for, it will not be terminated.
Are there any other speaker cables that are a similar price to the Chord's C Silversreen (apart from QED Silver Anniversary XT) that are as good or better?
