Chord Epic speaker cable - Should I buy
English is not my first language
i have Receiver Pioneer 85
Speakers KEF 900 Q
Should I buy these speakers cables ?
Are these bananas are good?
http://www.ebay.com/itm/4-Pure-Silver-Plated-Banana-Plug-Speaker-Cable-Wire-Connector-Hi-Fi-MHP04-/300604528146?pt=UK_Computing_CablesConnectors_RL&hash=item45fd6d1612
These cables better silver or gold bananas?
Deliriumbassist
101
62
18,670
I have Chord Epic on my Q500s (plus the signature links, which made a big difference), and am very happy with it When I had my CM1s, the soundstage increased, but also more cohesive, once I upgraded from Rumour to Epic.
In terms of the banana plugs, I would just have Chord put on their own terminations.
What a change it made​​? What improved?
why only
I feel cable Chord Epic blocking frequencies
The good thing about this cable Chord Epic is blocking madness Bass in speakers
why only Chord banana plugs ? I am looking for an expert's explanation
Does this new cable Chord Epic should make running 100 hours
To touch his prime ?
nopiano
Chord Epic is a very good cable. It may be too good for your system. The Chord Odyssey is half the price and will probably perform very well. The Odyssey won many awards.
Personally, I would avoid add-on banana plugs. Better to have them soldered onto the speaker cables by the manufacturer. Silver is unecessary. Gold is fine.
I hope this helps.
I hope this helps.
Thanks for your help
why do you think it's too good Chord Epic to my receiver ?
(I hear something in the cable not quality but do not understand why? )
I need for this cable Chord Epic bananas just thick the cabel
What's wrong with these silver bananas? 99% Silver ?
In my country they want for this bananas 113$
http://www.chord.co.uk/products.php?pg=60
nopiano
I trust the original manufacturer. They recommend what they do for a reason.
I dislike silver as it tarnishes, and if it was of the necesary quality it would cost a lot more. However, for a few dollars why not try it for yourself?
Idislike silver as it tarnishes, and if it was of the necesary quality it would cost a lot more. However, for a few dollars why not try it for yourself?
I bought a silver banana test
I tried Cables Chord Epic speaker Cable block many frequencies
Not for me No musical
Odyssey
Sound unnatural
Van Den Hul Are these cables could be better ? Which model better ?
I found the source of the problem
I got new speakers Q900 one of them takes out a metallic sound
And i replaced it
I tried Cables Van Den Hul MAGNUM and Van Den Hul D-352Very disappointing
I tried again and Chord Epic +Odyssey
Stunning
And winning Chord Epic :cheers:
Thanks for helpers
