- Aug 10, 2019
- 2,556
- 4
- 0
My kit is :
Sony STRDA-1200ES AV Receiver
Sony RDR-HXD860 DVD Recorder
Toshiba SD370E DVD Player
Rotel RCD-02 CD player
B&W DM 602.5 S3 Front Speakers Bi-Wired
B&W HTM62 Centre
REL Storm Sub
Mission 760i SE Rears
I am currently using Cable Talk Talk 3 Biwire cable for the fronts, Talk 3 standard for the centre I believe (no brand visible on the cable sheath) and a standard QED cable for the rears.
I am wondering if it's time to to go something a little more up to date for the fronts and centre, but I dont want to spend more than about £ 5 - 6 per metre,
Am I better off staying with the Talk 3 given my limited budget right now, or would an update still be worthwhile ?
If a change is recommended, go with a standard or a Bi-Wire cable for the fronts ?
And what cable would you recommend ? The kit is used slightly more for Home Cinema than music.
Thanks.
B&W HTM62 Centre
REL Storm Sub
Thanks.
