abacus said:There are less differences between entry level and High End amplifiers then between entry level and high end speakers.
Hope this helps
Bill
But that doesn't mean you can use a Pioneer A20 with a pair of SCM40s. It's a case of balance.abacus said:There are less differences between entry level and High End amplifiers then between entry level and high end speakers.
Hope this helps
Bill
David@FrankHarvey said:But that doesn't mean you can use a Pioneer A20 with a pair of SCM40s. It's a case of balance.abacus said:There are less differences between entry level and High End amplifiers then between entry level and high end speakers.
Hope this helps
Bill
To answer the OP, I'd say it depends on the definition of 'cheap', and what sort of budgets we're talking about here. I'd rather have a £2k AV receiver with a set of £900 speakers than the other way round. A speaker does what it is told to do, so is limited by the amplifier. The amplifier is amplifying the signal it is receiving. The signal it receives depends on the quality of processing/digital conversion.
It depends more on how demanding the speakers are. Usually, more expensive speakers (usually better ones) tend to be more demanding of the amplification. There are some models or ranges that don't demand too much of the amplification (although they will still respond well to more watts/better quality of amplification).Animesh Ghose said:hi David, my speakers cost almost twice as much as my amp.
would you call it a mismatch?
CnoEvil said:Cheap speakers (within reason).
It was a simplistic question, to which I gave a simplistic answer. Taken to extremes, I would rather have a £4k amp driving £800 speakers, than the other way round.MajorFubar said:It is all about balance, otherwise it could probably be argued you're not getting the best from either your speakers or your amp, but the valid point Bill was making is if you could somehow rate the percentage improvement in a product-category as you increase the price, speakers would easily take the lead as there is a far bigger difference in sound between a £1,000 pair and £150 pair than there is between a £1,000 amp and a £150 amp. I would agree, and just to complete the list, the least difference of all is attained by ugrading your digital source, but that does not hold true of an analogue source.
