Charging question - iPad 4
psurquhart
318
Quick question about my new A grade bought from CEX iPad 4 64gb please. Very pleased with it considering I bought it with vouchers from selling things over the last couple of years.
Having not owned one before can I charge this using my iphone 5 lightening charger rather than the adaptor that comes in the box ? Probably a silly question but just trying to keep my charger count down.
Looking for a quick reply please ! Need to charge it.
RodhasGibson
191
9
18,595
Hi There,the answer is Yes you can although it will take longer.The best way is to use the iPad charger to charge both.That way you will get a quicker Charge on both devices. :)
Deleted member 2457
psurquhart said:
It does work, but I don't think it is as good though, but yep.
psurquhart
318
Ahhh, right. Will do this then instead.
Cheers to both reply's.
