CETECH upgrade for LP12
Clarkey_71
214
100
18,970
I'm not sure if the forum rules allow for unlicensed products to be discussed, but as a long time LP12 user I wondered if anyone had any experience of the CETECH device?
There is absolutely no way I would consider to £2000 for the Keel upgrade, but it would appear that the CETECH upgrade is a very good and cheaper substitute.
Any comments would be greatfully received.
Thanks.
Paul.
T
the record spot
Have you tried the Vinyl Engine forum? That's probably worth checking out; also the Steve Hoffman Forum - Audio Hardware subsection. Both forums are likely to have had at least some users of the upgrade you're referring to.
Good luck!
