Following on from my previous thread:
http://www.whathifi.com/forum/hi-fi/cd-6004-with-ipod-connected-via-usb-marantz-dac-or-internal-ipod-dac-used
...Where I tried to establish the way in which way the Marantz CD6004 receives digital data from an iDevice when plugged in to the front USB port. I now have my answers.
At first I was unconvinced that the connection was truly digital, purely because all other dedicated iPod/iDevice digital transports I have seen use a docking port rather than a simple USB connection which the Marantz has. In addition all these 'seperate' iPod digital transport devices are all north of £150 also, so surely the Marantz couldn't have this feature included in it already modest price? I set out to find out to get to the bottom of it. The primary motivation in my persual of the facts is because I want to avoid using the Apple devices on-board DAC, which can be arguably be improved on quite easily.
First I emailed Marantz my technical query, but this took days to be answered.
In the meantime, I started by trying various connection methods between the iPod, CD6004 and my AVR (I am using the AVR rather than my PM7004 amp purely for the Toslink/optical connection) to see if I could find out myself.
I removed the phono RCA connections and used ONLY an optical cable between the AVR and CD6004. Logic suggests if the iPod would play its content through the CD player/AVR in this state of connection, it would go some way to prove the outgoing iPod signal IS digital, going straight through the CD6004 and out optically before finally using the AVRs DAC. After all, if the signal reaching the 6004 has already been converted to analogue, its hardly going to then reconvert to digital for transmission out from the optical connection.
At first attempt I got no sound at all. Conclusive I thought: the D-A-Conversion is performed on board the iPod, explaining the lack of any sound.
But then I played with the menus on the CD6004, and switched the USB OUT mode from '1.Analogue' to '2.Digital'. Bingo. Now I had sound coming through my speaker. Sounded good too. Did this mean that the Marantz can act as digital transport for the iPod/iDevice through its USB port? It certainly seemed so.
I then played some of the few albums I have stored on the iPod (I'm much more a CD man than digital media) in WAV and Apple Lossless through the CD6004, and then compared them to the original CDs (for fairness using the CD6004 as CD transport only via optical output to the AVR DAC for conversion, as per the iPod). I could tell no discernable difference is sound quality whatsoever. This lead me to conclude that the CD6004 can be used as a purely digital iDevice transport.
I then received this back from the Marantz technical support team a couple days later:
"Dear Mr Xxxxxxx,
Thank you for your inquiry.
Both the CD6004 and its predecessor the CD6003 both facilitate a Direct Digital interface with iPod, bypassing the iPods built in DAC.
We've had this technology for a number of years now and indeed were actually the first manufacturer to license & feature such a direct digital access technology.
Thank you
Sincerely,
Marantz Customer Support"
So that confirms it.
The fact you can bypass the iDevices DAC and listen to your stored music with outboard DAC conversion via either the Marantz's own high-quality DAC (it must be good given how well it performs as a CD player) or via optical output for conversion through a seperate DAC adds considerable value to the already outstanding CD6004. For less than £300 you get an award winning CD player with added iDevice digital transport capabilities, and use of a remote control too. This then leads me to wonder the value of costly dedicated iDevice transports, such as the Wadia 170i (£350), CA id100 (£150) and other offerings from Arcam and Onkyo, as all these devices really do is extract the iPod data for DAC conversion elsewhere - which is where the real SQ improvements are made.
Sorry if I have bored some of you with my experimentations and pursual of the technical side of things! I'm an electrical/electronic engineer by trade and love to know how my things work, if only to allow me to make better choices in how I choose to use my equipments features and connectivity.
I hope this may have been of some help to some of you too.
Keith
"Dear Mr Xxxxxxx,
Thank you
Sincerely,
Keith
