CD Micro System with Lightning adaptor
thegravy
Hi
I bought my mum a iPad mini last year and now want to get her a micro system so she can play all her cd's and itunes and listen to DAB radio.
anyone bought something similar, a lot seem to be for the old 30 pin adaptor, not the lightning, ideally don't want a cable for the lightning but rather a dock!
thanks in advance
BenLaw
475
7
18,895
A few options are starting to appear now with lightning docks. The best option IMO is the panasonic PMX7DB. Onkyo I think also do one. However, I don't think either of these would fit anything larger than an iPhone. You could use an older model with a 30 pin dock and use an adapter. The standard adapter may give you stability problems. Last time I checked a better option would be the flybridge dock or the photofast lightning mount, although you may have to import these.
thegravy
Hi
thanks for the replies, I was looking at something like this
http://www.philips.co.uk/c/audio-system/dock-for-ipod-iphone-ipad-dab-plus-dcb2077_10/prd/
or something similar, just wondering if anyone had any experience with these
ta
