Cartridge Upgrade
chris_bates1974
Moderator
Feb 28, 2013
96
34
10,570
Hi everyone,
I have a Project Debut Phono fitted with the original Ortofon 5E cartridge... I'm wondering what the best options are for replacing/upgrading it... I may also soon replace the turntable, so any ideas on next steps there would be appreciated also.
thanks!!!
nima
29
Anything from Nagaoka, Audio-Techica or Grado in your price bracket will be great.
Different things for different people though.
plastic penguin
1,880
229
20,070
chris_bates1974 said:
Hi everyone,
thanks!!!
You'll get a bigger upgrade in sound with a better TT, so decide if that option is feasible. If you decide to keep the Debut then perhaps look at Goldring or perhaps Shure. They both produce fabulous budget carts.
chris_bates1974
Moderator
Feb 28, 2013
96
34
10,570
Thanks guys... So if I replace the TT, do you think another Project? I had a Planar 3 back in the dark mists of time, what are the newer Regas like?
or are there other options?
plastic penguin
1,880
229
20,070
If you mean 'out of the box' difference then there's nothing to choose between them. If, on the other hand, you want to upgrade a TT then, perhaps, Rega has the edge.
Really boils down to whether you're a tweaker or not.
T
the record spot
Audio Technica AT440MLa. Killer cartridge that'll last many an upgrade.
steve4232
6
If you like the sound of the Ortofon, why not stick with the brand? They make some truly outstanding cartridges. Have you heard a 2M Blue? I agree with PP though, if you're a "tweaker" maybe you should try a Rega table next. If not, then you'd have to go a long way to beat the Pro-Jects. If you check my signature you'll note that I've just joined the "Pro-ject club" after upgrading from my trusty 25 year old Linn LP12. I was genuinely surprised that the company can compete at all price levels.
plastic penguin
1,880
229
20,070
Thanks everyone, I think I'm going to look at an Ortofon or Grado - they seem to get pretty decent reviews....
Nice one - I have the Xpression 1 and I have the ClearAudio Classic Wood cart fitted. Very decent improvement over the standard Ortofon, as you would expect given the price difference.
Pro-jects, even budget ones, are very good when it comes to hearing the difference with a better cart. That said, I would still recommend a TT change if you're looking for a significant improvement.
ASK THE COMMUNITY
