Second , you can bi-amp your speakers if you buy another AS-500 ... you don't need it on this level price of speakers .
[/quote]
Yes, you COULD... However, the AS500 does not have pre-outs, so you'd have to use tape-outs (fixed level) and adjust both volume controls in unison to get the correct balance. This is obviously not ideal, and having two integrated amps on your rack would look a bit daft...
Biamping is best kept for dedicated amps that are designed to offer the feature- for example, my Rotel integrated has preouts to feed my RB03 power amp- I biamped until I changed to single-wire speakers.
[/quote]
Being perverse, as I often am, you could use one AS 500 per channel, 'horizontal' bi-ampling rather than the more normal method. The volume control on each amplifier then would work each speaker, ie individual volume for each channel rather than the normal volume and balance.
I do remember trying out such a setup aeons ago, but for the life of me I can not remember why I would have bothered....... :?
