Can pioneer A-20 Amp run fully monitor audio BX-5
aria46
Hi
Could you plz advise if pioneer A-20 can run MA BX-5 (spk) .
Which amplifier could run better MA BX-5 just for music :
Pioneer vsx-528
pioneer vsx-923
pioneer A-20
If you can afford it go for the Pioneer A-30. The A-20 will work with the BX5 speakers but the A-30 is a little bit better and has more power.
Thank you
But A-30 is not available in my country.
What is your openion about pioneer AV AMP.
Thank you Cypher
A-30 and the other integrated amp of pioneer are not available in my country. Just A-20 and the full range of pioneer Av Reciver are available.
What is the quality of vsx-528 or vsx-923?
Thank you very much
Have you considered second hand on auction sites? Also, what brands are available in your country?
If the full range of AV-receivers is available, I would try to get an SC model. The amp in the SC models is much better than in the VSX models.
Thank you
Pioneer AV amp VSX series are in good price in my country.
But I dont know if their quality are good for playing music or not.
The yamaha integrated amp s300 and s500 are available in acceptable price .
I think Yamaha is not match with BX-5 because it run low trible sounds.
Thank you
If it's just for music, I wouldn't choose a VSX amp. If that limits you to the A-20, S300 and S500, I would definitely choose the S500.
because it run low trible sounds....? :?
low or treeble ??? Yam AS 500 is very good,
but perhaps a little bright for M Audio...
