Can NAD C316BEE/Marantz PM5004 drive floor-standing loudspeakers?
Magma
I just got a pair of Monitor Supreme 800 floor-standing loudspeakers (2.5-way bass reflex with double bass, recommended amplifier output 30-320 watt). Now, I'm looking for a decent budget friendly stereo amplifier that can drive them for my first beginner-level hi-fi system (my budget is 250 euro max.)
Stereophile and The Absolute Sound magazines recommend NAD C 316BEE (45 watt, €240) and Marantz PM5004 (40 watt - 8 ohm RMS, €230) amplifiers.
My simple question is: can I use these amplifiers that have 40 watt outputs to get a good sound from Magnat 800 floor-standing speakers? (Magnat recommends minimum 30 watt, max 320 watt)
Or I should get Denon PMA-520AE (70 watt, €175) or Pioneer A30 (70 watt, €230) instead?
Thanks, Berk,
-Any beginner-level amplifier recommendations would be more than welcome for these speakers.
Cypher
156
I would get the Pioneer A-30 (I have one myself) and it will drive your speaker without any problems. The sensitivity of your speakers is 92 db........no problem for most amplifiers.
Magma
Sorry I forgot to give details of the speakers:
Principle 2 ½ way bass reflex
Equipment 1 x 170 mm woofer
170 mm woofer-midrange
25 mm tweeter
Power Handling (RMS / Max.) 160 / 320 watts
Sensitivity (2.8V/1m) 92 dB
Impedance 4 – 8 Ohms
Frequency Response 22 - 38000 Hz
Crossover Frequencies 500 Hz / 3500 Hz
Recommended Amplifier Output 30 - 320 Watt
Dimensions (WxHxD) 215 x 850 x 273 mm
Weight 14 kg
Link: http://www.magnat.de/en/home-audio/audiophile-speaker/monitor-supreme/monitor-supreme-800
