FrankHarveyHiFi said:
Yes, you can. Which sub you choose will be up to you, but it's a case of matching the sub to the room. Quite often people will choose a sub based on it's size (meaning small), but they find (or are oblivious) that the sub isn't enough to fill the room efficiently, and can end up struggling, causing distortion, bottoming out, or overheating.
So, would this be the primary difference/ability, DF for concrete floor and FF for suspended?
What of the internal arrangement excluding the factors above, are there limitations there, i.e FF has free space ahead of the sound wave, DF has a floor (of whatever material) to contend with maybe just 50/75mm from the cone, what of design criteria to accommodate this structure, are there no issues with this arrangement?
I think the OP's point/question is, as is mine, enlighten us please.
Or is it all smoke and mirrors?
