Can I have your recommendations for cleaning vinyl
Hi
I want to clean up all my old vinyl so can I have your recommendations on how to do this. I read about a record cleaner which did a good job by giving it a bath in a liquid but not to use the supplied liquid as this caused a build up of white stuff on the stylus.
How do you clean your vinyl? Recommendations please.
I've heard excellent reviews about the Knosti Antistatic cleaner. It's a wet cleaner, but a cheap alternative to the vacuum models (retails at about £40). Do a search on amazon/ebay for it.
DistortedVision
213
36
18,820
I started off with a Knosti Antistat but I would really recommend a vacuum cleaning machine. I would highly recommend the Cadence Okki Nokki and strongly recommend L'Art du Son record cleaning fluid. Its not cheap but one bottle goes a long way and I've had excellent results with it.
Rob998
6
I use a Knosti and it is great. However I make my own fluid due to residue issues with the supplied stuff.
1 part Isopropyl Alcohol (99.9%)
3 parts Distilled (or de-ionised) water
a couple of drops of dishwasher rinse aid (no particular brand, just whatever Mrs Rob has bought)
All easily available from the net (apart from the rinse-aid, which is easily available from under the sink....), I use http://www.apcpure.com/ but other lab supply companies are available.
mitch65
52
+ 1 for the Knosti.
Never had a problem with the supplied stuff apart from the price but like others here I am in the process of making my own as it's so damn easy and no need to re-use being nice and cheap. :grin:
I bought a used Moth vacuum record cleaner from eBay. it does an excellent job, and well worth the money if you have a large number of records.
What ever cleaning option you go for make sure you rinse the records thoroughly as I found any detergent left behind resulted in pops and crackles and significantly poorer results.
Cheers.
The best way is a vacuum type machine, it doesn't matter what make it is. I've tried other methods and apart from being very labor intensive they are nowhere near as effective.
