Can anyone recommend a wifi booster?
Ben123
21
A not so tech savvy friend of mine asked me to install one in his house. I went for the affectionaly named TP-LINK TL-WA830RE as it was only 30 notes and got good reviews. I've given it a trial run in my house and its a big improvement over the crummy sky router i have.
Havent got round to installing it at his house yet but hopefully it will do the trick with his lead walls or whatever he has :grin:
MajorFubar
690
6
Unless you really need the WiFi I'd recommend you take a different route and buy homeplugs. It's the best thing I ever did.
Nothing truly beats connecting two things together with a cable.
hammill
212
Thanks, I already have homeplugs which do indeed work well. My tablet, phone and son's ipod all require wireless.
hammill
212
Thanks, but that is a bit big - I may want to deploy on the landing, so one of the plugin ones is probably more suitable. I notice on Amazon that there is a TP-LINK TL-WA850RE which fits the bill.
MajorFubar
690
6
Ah fair do's...just thought I'd mention it in case you'd never heard of them. I hadn't heard of them 'til quite recently, nor have most of the people I know.
relocated
74
Will an Apple Airport Express do the job? Link it to your router and it creates another wifi zone as well as other things. Not very cheap I suppose but I'm sure I have read that it is a solution.
hammill
212
Feral said:
Useful utility for checking if neighbours or other devices are hammering a particular wireless band. Enables you to choose a quiet band and potentially improve performance although you may have checked this already.
http://www.metageek.net/products/inssider/
Feral
I have already changed channel, but thanks for the suggestion. It is a long way from my wireless router to the back of the house.
LateDev
There are devices called powerline wifi extenders, which combine the powerline technology, but the receiver also Transmits/Reveives wifi. Ideal for those with pads and game boxes with no ethernet connection.
hammill
212
As It happens, that is what I got in the end.
Paul.
What router do you have? It may be worth considering replacing the router with a better one rather than adding and extender to the network. Adding an extender can slow down the network. I really rate Asus routers, N66 is bullet proof and very fast.
emptage
56
I had the problem of wi fi not reaching parts of my house. Power plugs were not possible as some rooms on a different circuit. I was using a Virgin Media superhub. What I did was to use the superhub as a modem only and purchase a Netgear Nighthawk router. This has brilliant coverage and solved my problem
