- Aug 10, 2019
- 2,556
- 4
- 0
Hi.
I ask because I don't know
Is it possible to connect azur 540a v2 to a subwoofer? ; the manual says :
Pre-Out connections
The Pre-Out sockets are for connecting to the input sockets of a power
amplifier or active subwoofer. The diagram below shows how to connect
the amplifier to an active subwoofer via the Line In inputs on the
subwoofer.
My subwoofer has :
Built-in Amplifier
Yes
Stereo (Screw Terminal)
Yes
Mono (Pin Jack)
Yes
Speaker level Input Sensitivity/Impedance (100 Hz)
2,0 V + 2,0 V / 15 k Ohm
Line level (RCA Jack) Input Sensitivity/Impedance (100 Hz)
200 mV / 50 k Ohm
do I need Y cable ( 2 RCA amp preouts L R ---> 1 RCA subw) or two sets of speaker cable?
thank you .
Pre-Out connections
subwoofer.
My subwoofer has :
Built-in Amplifier
Yes
Yes
Mono (Pin Jack)
Yes
200 mV / 50 k Ohm
thank you .
