Cambridge Audio DACMAGIC 100
moon
47
:bounce:
Does anybody know the release date for the above, as it is on my hit 8) list.
It's on my hitlist too...................I believe it's available next month but Ï'm not sure.
Hi there,
Apologies in the delay in getting back to you both!
The DacMagic 100 will be available in stores in early March.
We'd recommend contacting your dealer to reserve one to avoid any dissapointment.
Kind Regards,
Cambridge Audio
Have been waiting to have a listen/borrow this from the Cardiff store to try in my Sonos system.
1. Will this work with the Sonos ZP90?
2. Will it up-sample?
3. Have the bass issues been resolved? (muddy-ish sounding in the old one)
4. Can you post the dimensions? (a minor detail I know)
Many thanks.
Many thanks.
Yes, the Sonos ZP90 has a digital output and will work nicely with the DacMagic 100.
The DacMagic 100 does not upsample, however, it does use the new Wolfson WM8742 24-bit DAC and will accept up to 24-bit/192kHz input from its digital inputs and USB audio input.
Obviously difficult for us to comment on this as the original DacMagic won hundreds of awards for its sound quality and operation. We are very happy with the sound of the both products and would recommend an audition as soon as the unit is available so that you can hear it for yourself and form your own opinion.
The dimensions are as follows 105mmx46mmx120mm.
There is a great deal of info on the DacMagic 100 in the link below if you've not read already?
http://www.whathifi.com/news/world-exclusive-cambridge-audio-unveils-%C2%A319995-dacmagic-100
Also, we’re happy to provide some answers here, but for technical enquiries we do ask that you contact our technical support at http://support.cambridgeaudio.com/ where you will get the quickest answer.
Regards,
CA
__________________
Cambridge Audio / Mordaunt-Short
We are happy to post where appropriate, but for enquiries please contact us directly via our customer support websites http://support.cambridgeaudio.com/ andhttp://support.mordauntshort.com/ where we will be happy to help.
There were no bass issues with the Dacmagic, one can only assume you had other issues relating to room acoustics.
Richer Sounds are now advertising them for sale on their web site
