Cambridge Audio CD player, sugget pls
Clare Newsome
1,657
Always go with the best source you can afford - you can always upgrade the other components at a later date. So it'd be the Cambridge Audio 640C V2 for me in that combination.
vinod_david
142
33
18,620
is it mandatory that 640 should be coupled with 640 only? what if i couple 640C with 540A, will that affect the overall perfomance ?
Yes and No.
Yes - It definitely will as a matter of fact
No - If you can't tell a difference
Andrew Everard
1,878
[quote user="vinod_david"]is it mandatory that 640 should be coupled with 640 only? what if i couple 640C with 540A, will that affect the overall perfomance ?[/quote]
No, not at all. Yes, the 640C is a better player than the 540C, just as the 640A is a better amp than the 540A, but as Clare said it makes sense to spend more on the source component for the best performance, as information lost at that point can't be recovered in the amplifier.
So the 640C/540A combination will work very well indeed.
