Hi all, last year i bought the Cambridge Audio 640 CDP/ Amp combo, directly as a result of this mags recommendation, fantastic buy - thank-you WHF, i'm now looking to upgrade my speakers, don't know where to start really, i'm hoping someone on here can help me draw up some kind of shortlist for me to demo.
Criteria:
Speakers that have caught my eye - not ears yet, not demoed any, are B&W CM1's - nice compact size, concerned about their sensitivity though with my amp, and the 685's basically just cos they are B&W- i've heard that B&W are good with rock music, and the fact the ports are front firing, which i'm informed, should be able to be placed closer to a rear and side wall than their rear firing counterparts.
Budget - Max £ 750, inc stands - i've heard that if spending under £1000, go with standmounts.
Room - Sixe is 4.5m x 5.5m Thick pile carpet 2 + 3 seater leather sofa, open plan staircase....
Speaker Position - in corners of the 4.5m wall, when i say in the corners, i mean as close as i can, prob will get away with pulling them out 18". My position will be 4m away from each of these speakers. Live in a semi detached house, one of these speakers will be on the adjoining wall.
Music Tastes - Rock, Metal. Anything from Def Leppard to Slipknot.
Other - Want a speaker that looks pleasing to the wife's eye, even if it means me saying "look, they do look nice, you'll get used to them, dear ... Whilst delivering a sound that is, well, i want to hear everything from the deep sharp thud of a kick drum to every cymbal crash.
Upgrade - Wanting a speaker that will be not be out of place when i upgrade my amp or cdp.
Any advice greatly appreciated. I'm hear to listen and learn.
Criteria:
