I wonder if any of you clever types might be able to point me in the right direction please?
I'm attempting to make use of the optical audio output from my Panasonic plasma (TX-P42G30B), but for some reason the main sound menu isn't displaying all the options that the manual says there are. (I'm attempting to get sound from my TV to my receiver's zone 2 output, but as my receiver isn't fancy enough to output HDMI sources to Zone 2, I'm trying to use the optical out instead).
The manual says there's a list of almost 20 sound options, including the one I want which is called "SPDIF Selection", but when I pull up the main sound menu it only gives me 2 of these 20 options, "Headphone volume" and "HDMI1 input".
The manual indicated there was a way of reducing menu options (so if you're not too technically competnt you can't do anything stupid, with the TV at least). The manual said I can display these extra options by going into SETUP >> ADVANCE (isfccc) and switch this toggle to "ON". I did this, but when I go back into the sound menu is still only displays the lame 2 options.
Does anybody know how I might be able to access this SPDIF sound setting? I've spent a couple of hours on this now so it's getting a little frustrating. I would imagine it's one of those "easy when you know how things"! Anyway, any advice that gets me further will be much appreciated. Many thanks.
