calibration for pioneer pdp 428xd
hi dose any one have the best calibration settings for the pioneer pdp428xd obtained either by using calibration discs or the spyder which i think attaches to your screen and then gives you the proper set up for gray scale colour contrast etc etc
hi i set my 428xd with the spyder but i got different readings by using two different dvd machine the spyder only dose basic set up .i have just used the settings below and the picture is much better the blacks are black and skin tones look natural you can change the colour saturation in the first set up,and change the sharpness as required.
For sky hd,cable, ps3,b/ray,or hd/dvd.
AV selection "Movie"
Contrast 30
Brightness 0
Colour - 2
Tint + 2 towards the green
Sharpness - 15
Pro Adjust "Pure Cinema
Film Mode off
Text Optimization off
Inteligent Mode off
Picture Detail
DRE off
Black Level off
ACL off
Enhancer Mode 2
Gama 2
Colour Temp Manual ( hold enter button for 3 seconds )
Colour Temp R High -2
G High 0
B High +2
R Low -1
G Low 0
B Low 1
CTI off
Colour Management
R - 0
Y - 0
G - 0
C - 0
B - 0
M - 7
Colour Space 1
Noise Reduction All Off
FREEVIEW.
A/V Selection - User
Contrast 27
Brightness 0
Colour - 8
Tint 0
Sharpness - 15
Pro Adjustment Pure Cinema
Film Mode off
Text Optimiser off
Inteligent Mode off
Picture Detail
DRE off or Low
Black Level off
Enhancer Mode 2
Gama 1
Colour Detail
Colour Temp
R High +2
G High -2
B High -14
R Low +1
G Low 0
B Low -1
Colour Space 1
Others
IP Mode 1
hope this helps
gaza
thanks gaza for the post alsow i found this last night check it out www.hdtvtest.co.uk looks a very good site for this sort of thing
Are these the best settings for HD only, or will they also be best for SD.
