- Aug 10, 2019
- 2,556
- 5
- 0
Right so I've got the main products - Cambridge Audio A1 Amp, Cambridge Audio CD4 CD player, and a pair of Tannoy M20 speakers.
All I need now is some analogue interconnect and some speaker cable. What would you suggest - I really dont want to spend much here so I'm guessing speaker wire wise I'm best off with some QED Silver Anniversary XT or some Chord Company Carnival SilverScreen; which of these two would be best? I haven't got a clue what interconnect to get - again I really dont want to spend much (nor more than £15ish really - so maybe getting some second hand would be best? What would you recommend?).
I also need some speaker brackets for the speakers because I have no room for standmounts - the speakers weight 7kg and are 21cm deep - any ideas? Is the best thing to do just to get some secondhand off ebay?
ANY COMMENTS AND ADVICE WOULD BE GREATLY APPRECIATED!!!!!! 🙂
