Cable upgrade?
cheyworth
145
Will the 'Chord Chameleon Silver Plus' give a better sound than my Van Den Hul D102 mk3?
Looking for more detail and better bass.
Chris
Hi Chris
I have both the above Interconnects, and upgraded to the Chord. For me, i found both slightly better detail with the Chord and notably improved bass. Put it this way, i now use the chord for my primary source which was an Arcam CD73t but is now a Fubar DAC. I think you will be impressed. I would try and get a 2nd hand one though as there are normally some bargains kicking around.
Hope this helps a bit.
