A admin_exported New member Aug 10, 2019 2,556 5 0 Aug 9, 2011 #1 I want to connect a Cyrus Pre Xp d Qx to a X-Power. That I buy cable? Chord Chamaleon Plus or Wireworld The oasis 6?.Thanks.
C Crossie New member Aug 4, 2009 58 0 0 Aug 10, 2011 #2 Why not give the Cyrus interconnect a try - works well for me.
MUSICRAFT Well-known member Mar 23, 2009 3,008 1,222 22,570 Aug 11, 2011 #3 Hi mike43 I'll recommend that you use a standard interconnect (usually with red and white coloured ends) as this will be more then good enough for your electronics. All the best Rick @ Musicraft
A Anonymous Guest Aug 11, 2011 #4 Thank you very much for his help Musicraf and Crossie. Regards from Spain.
