Cable for M12.2
Hey,
I have finally decided to go for a Epos M12.2 and a Marantz PM 7001 (ki if I find one at a good price)
I hope that they will like my Zune..
Which cable do you think I should use with it??
Thanks.
gpi
23
I was reading through the PMC site yesterday and came across this advice:
8. What speaker cable should I use?
PMC recommend using a high quality think [thick?] multi-strand Oxygen Free Copper (OFC) cable between the amplifier and speakers. The use of 'exotic' cables has limited improvement on sound quality, so we would not advocate spending great quantities of money. However, if you are prepared to spend a great deal of money in this area, we would strongly advice you listen first to determine whether the outlay is worth the improvement.
[quote user="verhoeven"]
Hey,
Thanks.
[/quote]
As thick as possible multistranded. No need to spend more that a fiver a metre.
Thanks for the reply...
But do I really have to spend 18 Quid a meter on a cable?? It seems pretty amazing to me....
