Hi!
I am new to this, and would really appreciate your help. I want to have good sound in my apartment when playing music, and I am considering buying two BW 685 s2 speakers. The seller suggests me either Denon or Nad receiver (he does not sell other brands). However, I found out that because I have a HTC android phone, I will not be able to stream music via wifi, only via bluetooth which should give much worse quality. Then I found out that Pioneer has HTC connect in their receivers, which means that you can use wifi. So, my question is whether it is a good idea to buy a Pioneer receiver for these two speakers, and if yes, which one would you recommend? I am asking because I found a forum message where a guy's Pioneer receiver and BW speakers did not match according to Pioneer.
In future I might want to add an extra wireless speaker to the bedroom. Will it be possible to have the two BW speakers connected with cables and the wireless speaker connected wirelessly such that they play exactly the same (i.e. you can walk from room to room and the music is the same).
Thank you!
Alex
Thank you!
Alex
