Buying 2nd Hand B&W Speakers
Dermondo
132
Hi, to make clear from the clear from the very start apoligies if this topic is breaking any rules it is not intended.
I am in the process of buying some B&W speakers used and I understand that B&W do not transfer the warranty, so that would mean no warranty for me as a second, is this correct or am I misunderstanding the situation or are they other options available to counteract this, many thanks in advance.
Frank Harvey
567
That is correct - the warranty isn't transferable.
Having said that, speakers usually stop working for a reason, so if they're in full working order, and you treat them nicely, there's no reason why you would need to call upon any warranty anyway.
