Hi all
BURNING COMPACT DISCS - OPTIMUM RECOMMENDED SPEED FOR ACHIEVING BEST QUALITY
Is there a particular recommended speed at which recordable CDs should be burnt to achieve the best recording / reproduction quality. It is said that recording at lower speeds gives better results as compared with recording at higher speeds. Is it true? What then is the optimum recording speed?
Are there any particular brands of recordable Compact Discs that are better suited for this purpose and which are the better branded CD Burners one should use (installed on a PC)?
Thanks.
Steven Kay
Thanks.
Steven Kay
