- Aug 10, 2019
- 2,556
- 4
- 0
Hello Forum!!
I'm current researching in to buying a good solid hifi separate system. Basically I want an amp, cd player and a nice sound (may add db radio later)
I'm looking to spend £350 - 450 on it, does anyone have any good recommendations? It's a minefield out there if you don't know what you're looking at!
Also, I'd very much like to have a speaker set in the living room and dining room which i could switch to either or both as I desire. is this easy to do even if the amp doesnt have two speaker outputs?
So far I've seen this fellow which looks solid - http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/3856 its the NAD C515BEE CD and NAD C315BEE amp
Any help will be greatly appreciated!!!
cheers
cheers
