Budget CD Transport - Blu Ray player?
I currently use the CD section of a two box Denon DF101 mini system as a CD transport feeding my Musical Fidelity V-DAC. Whilst I'm very happy with the overall sound from my part-DIY system, I would like to remove the DF101 from the chain, largely because I also have to have the Denon amplifier connected, purely to enable the CD remote to operate. I also have an old Sony DVD player, and I am planning to remove a few boxes from my rack by buying a new DVD or Blu Ray player, both as a CD transport and as a video source. Blu Ray would be nice but not essential.
I am unclear as to:-
1. Will a budget Blu Ray or DVD player output a raw digital audio signal that can be processed by my DAC? I was thinking of the Sony BDPS 370 Blu Ray, or a Cambridge DVD99?
2. If possible, are the options above likely to result in a significant difference in sound from my current CD transport?
Any alternative suggestions, on a max £150 budget, very welcome
Andrew Everard
1,878
The answer to the first question is that yes it will, but of course the DAC will only handle stereo CD-quality or PCM signals, not multichannel Dolby/DTS variants.
The answer to the second part is really a matter of suck it and see: don't have any experience of using that Denon as a transport, so hard to make a call on that one...
A belated response to your helpful reply, Andrew.
After a chat with my local ever-helpful and knowledgeable Richer Sounds store, it was suggested that I trial a Pioneer BDP-LX70 as a CD transport. Software was even updated for me before collection. I was delighted with the sound quality and operation, and even more delighted with the discount price as an open-box item. It also fulfills my limited secondary requirement as a DVD player extremely well. The lack of compatability with the very latest Blu-Ray releases was clearly explained and is not an issue for me.
manicm
1,356
390
19,570
I could be wrong but there may be a caveat with using a Blu-ray player connected to a DAC when playing movies:
I have the Sony BDP-S370 connected through stereo analogue - and the sound is so stunning for movies that I'm sure a DAC would make no improvement here.
For music it may do - but here I suspect that for a budget player like the 370, the transport would be the weak link instead of the built-in DAC.
richardw42
299
The transport on my cheaper Sony does chug along a bit on start up and loading of discs.
Whereas my Marantz never makes a sound
ASK THE COMMUNITY
