Bryston BP25 gets warm. Normal?
newtohifijkt
hi,
i have bought a used Bryston Pre-amp BP25 yesterday. What I notice, the right side of the amp (around one-third of the case of the amp), gets warm during usage. Is it normal?
The sound is amazing. But haven't had the chance to use it for a lengthy period though.
tried to google it about the issue, but cant find answers. If somebody here who are familiar with Bryston pre amp can shed a light?
thanks,
Why wouldn't it be normal? Even my class D amp got warm (relatively hot in summer) but then again the case itself worked as the heatsink.
image.php
Oh, look. There on the right hand side. Around one third of the unit. Would they be capacitors, etc. associated with supplying power for the unit. (assuming I've got a picture of the right bit of kit or one similar enough).
Even my U-05 gets surprisingly hot overall, even just working as a preamp. Then again, that's probably the class A element at work. I think the use of class A in preamps is common because it isn't dealing with so many watts so doesn't waste too much power/generate too much heat.
If you are really that worried about it I would have thought Bryston Customer Service would be the place to enquire.
In addition, don't they do a twenty year or something like that transferable warranty?
I have a Bryston BP6 pre-amp which never warms up at all. I would give Bryston/PMC a call to re-assure yourself. They are said to be very helpful. Good luck.
This would certainly give you a better and more satisfactory answer than the opinion of random internet guy who has never heard or owned your kit (i.e. me).
