Brennan JB7
Senna 94
8
Hi
Is the Brennan JB7 any good i am building a en suite and fitted celling speakers and was thinking about the JB7 as it is small and neat to fit into bedroom and can you run more than 1 set of speakers of it as i would like it for the bedroom too.
Or are we better off with the Sony juke box thing that hold 300 CD.
Big Chris
400
Would you recommend sticking with the standard speakers, or would it be worth investing in something else?
EDIT: I really must reach the end of reviews before responding!! Sorry!!
This little unit has piqued my interest as a system for my bedroom.
Andrew Everard:
fast eddie:I think i remember AE doing a review of it in his blog.
Came out fairly well if i'm right.
here you go
That's the official review - my blog piece on the Brennan JB7 is here
Yes, i know it wasn't the same, but figured it would do.
Senna 94
8
Thanks guys
Think i will go with the JB7 perfect for a bedroom / bathroom and should be ok to link up the bathroom speakers with the ones in the bedroom.
Big Chris
400
Senna 94:
Thanks guys
Only one set of speaker terminals on the back. Not sure if it'll be happy running two pairs of speakers simultaneously.
Senna 94
8
I know what you mean Chris it was one of my concerns but i was thinking about a switch type box so you only have on the speakers in one room unless there is away to play both sets of speakers !
James2323
Hey there, does anyone no if the brennan Jb7 works with all types of Usb sticks or a specific type. Feed back will be appreciated
James
Mark34
Pretty sure all USB devices work with the brennan JB 7, my friend uses a standerd USB 2.0 flash drive to back up his music collection.
Andrew Everard
1,878
James
You'd have thought that, rather than resurrecting a thread last posted on four years ago, you two could've just had a quiet chat – what with both of you posting from the same IP address an' all.. |(
