Hi How do I brake speakers in out of faze ?....from what i understand it is not as loud as doing it the conventional way. Hope this makes scene . Cheers Luke
Set the speakers up, wiring them correctly. Then swap a positive and negative over on the back of ONE of the speakers, and set them up facing each other....
Pistol Pete1:Set the speakers up, wiring them correctly. Then swap a positive and negative over on the back of ONE of the speakers, and set them up facing each other....
...with just an inch or two seperating the fronts of the speakers. (Not facing each other from opposite ends of the room!)
