Bluetooth wireless streaming
Guessing on what you intended to ask, I would recommend this :grin: :
http://www.whathifi.com/forum/smartphones-tablets/crystal-acoustics-ovale-e-portable-bluetooth-speaker-first-impressions
EDIT: Just noticed that you posted this in HiFi section, so my recommendation would be this:
http://www.bose.co.uk/GB/en/home-and-personal-audio/digital-music-solutions/bluetooth-speakers/
Based on my guess at what you were trying to ask, I'd say the answer is
drummerman said:
Lost the will to live as I tried a few times to post and can't even save the text.
Ignore
I'm guessing that you need to 'Disable Rich Text' on a tablet of some kind or you need to read this:
http://www.whathifi.com/forum/about-the-new-site/important-notice-internet-explorer-users
Ah, oh, simple me. Ok, have any of you have experimented with wireless bluetooth such as this? http://www.logitech.com/en-gb/speakers-audio/home-pc-speakers/wireless-speaker-adapter I am not to anal about any high end credentials as it is only for spotify premium but would like a half decent connection without drop outs. - Would that compress and already compressed signal further? Anyway, have ordered one meanwhile but would consider a SB Touch if I find one at a reasonable price. regards
I'm using a Samsung HS3000 bluetooth thingy that utilizes the apt-x codec on my phone(HTC One X). Plug in your own headphones and the device can clip to your shirt etc and act as a headseat with volume, play, pause etc...
Excellent imo. But the Apt-X does make a difference, so I'd probably avoid non-equpped BT devices 🙂
+1 for aptx on Bluetooth ... Makes for a big improvement over normal Bluetooth audio codec.
Creative, Conran, Altec Lansing, Nokia do aptx speakers .. The Creative ones (D3x/D5x) even do multi-synch.
For conventional speakers /amps with a line input you can you aptx receivers from the likes of QED, Arcam, Chord, Nokia etc.
