Bluetooth for wired headphones
McThommo
43
19
10,545
I am looking to use my Grado SR325e with both my mac mini, Evo150 and iphone via bluetooth as i will mostly be in another room from the evo and mac. Any recommendations gratefully accepted
I not needing headphones, just a bluetooth dongle to allow me to connect my Grados- I have airpod pros for other use
Surely you just get a connection in the other room and it’s cheaper?
The Grado is a wired headphone. If you want to use it wireless, a portable Bluetooth receiver is the answer.
The Shanling not only has excellent specs (amp & DAC), it is battery powered.
The Logitech Wireless Bluetooth Audio Receiver is AC powered so not suit for portable use.
Edit:
But I must admit I do assume a mobile solution.
If this is not the case, a stationary box with Airplay or Bluetooth and a headphone out is a good solution.
Reactions: Gel and Al ears
Edit:
Correct with the mobile solution as I do work from a couple of different rooms from the source so a deskbased/stationary is not an option.
Trying a fiio one out which should be with me in a few days so fingers crossed
