Cheese said:whoops! sorry!:bounce:
I'm currently thinking about bi wiring my Arcam A75+ to my Linns.
The A75+ has two sets of speaker terminals, Speaker set 1 & Speaker set 2.
I would like to know if I can use the terminals of SP1 for Mid and High,and SP2 for Low?
Unfortuanetly I can not find this info in the manual..
Many thanks in advance!
davedotco said:Cheese said:whoops! sorry!:bounce:
Yes you can do that, it will work fine. Remember to select Speaker 1 and Speaker 2 on your A75+.
You can also, carefully, wire both sets of cables to one of the sets of speaker terminals, that will work fine to.
In fact, if you are careful and make all the connections correctly, it will sound every bit as good as the single wire option you started with.
Al ears said:Never too early for a bit of sarcastic whit.
Says he who has been up since 04:00hrs. 🙂
Particularly like the bit about vacuum's sucking PP
