- Aug 10, 2019
- 2,556
- 3
- 0
At the moment I have my Monitor Audio BX2 speakers biwiring jumpers removed and have the HF and LF wired seperately. These wires then all go into the A channel of my amp. Is this the best way of wiring them or should I run the HF from the A channel of the amp and the LF from the B channel. I'm not sure how it works but I was under the impression that by using A+B I would be splitting the power that would normally be available if I was only using 1 channel. Is this correct or do both channels have seperate amplification?
