FrankHarveyHiFi:
fowler:thanks david.do you use a s150 for the front 3 speakers or is there a dedicated centre available? im going to be upgrading my monitor audios in the coming months - iv got the s150 pakage in mind along with atc19's fronts c3c centre and atc7 surrounds, and monitor audio pl100s the matching centre and some gsfx surrounds! in your opinion how do they compare purely for movie use? my room is around the same size as yours. thanks.
One of the differences with MK is that the front L/C/R speakers are all exactly the same - only this can guarantee an exact timbre match across the front, and give far more realistic panning effects. This is why the 950's MAY be a little easier for some people to accommodate. They're also a far wider dispersion than hi-fi speakers, which helps positioning and opens up the soundstage for those not sitting in the sweet spot.
The PL100's are great for AV - they're very detailed, nice and sweet, but will need a good sub to back them up with. Also, the end result will depend on the amplifier being used. I heard them on the Arcam AVR600.
The ATC's are one of the closest speakers I've heard to MK with regards to movies. Nice and detailed, their leaner sound is a little more like the MK presentation, and they'll be easier to set up too as they're also sealed boxes like the MK's.
This is where I'm going to sound biased
. I've not yet heard any hi-fi speakers produce the same characteristics as the MK's. Their ability to bring out tiny details which would normally be quite subtle on hi-fi speakers is pretty amazing.
To work out whether you'd be an MK convert I think is quite easy - do you want to hear the soundtrack as it's intended? Imagine someone fires a gun close by - is it smooth and easy on the ear? I find hi-fi speakers tend to soften movie soundtracks - whether this is due to them being big boxes or whether it's because hi-fi speakers generally aren't flat frequency response I'm not sure, but I have my hunches.....
I can imagine the MK's are like you say good with movies, you say they let you hear the soundtrack as it's intended. But they aren't as good with music as some hifi speakers?? I'm not saying this could not be true, but how can a speakers sound as it should be with movies and not with music?? I like to hear the sound to be as intended, movies or music, both are sound are they?
