When bi-wiring my 8ohm speakers using my 65w x 65w amplifiers A&B terminals the speakers are now parallel at 4ohm. So is the 65w pair channel now divided into 4. so like 32w as if there are 4 speaker's connected
cal said:Main reason my onkyo a9050 amplifier drops from 75w pair channel at 8ohm to 65w pair channel at 4ohm bizarre I no. But says thick copper bus bars for easy low impedance drive. Don't want to biwire if power drops to much ad rather put the full 75w threw standard wiring if I am losing
something doing biwire
davedotco said:cal said:Main reason my onkyo a9050 amplifier drops from 75w pair channel at 8ohm to 65w pair channel at 4ohm bizarre I no. But says thick copper bus bars for easy low impedance drive. Don't want to biwire if power drops to much ad rather put the full 75w threw standard wiring if I am losing
Read my post again......*dash1*
Single wire, biwire, one set of terminals, both sets of terminals, it makes no difference.
Electrically it is identical, ok.
Covenanter said:davedotco said:cal said:Main reason my onkyo a9050 amplifier drops from 75w pair channel at 8ohm to 65w pair channel at 4ohm bizarre I no. But says thick copper bus bars for easy low impedance drive. Don't want to biwire if power drops to much ad rather put the full 75w threw standard wiring if I am losing
+1
Chris
abacus said:Covenanter said:davedotco said:cal said:Main reason my onkyo a9050 amplifier drops from 75w pair channel at 8ohm to 65w pair channel at 4ohm bizarre I no. But says thick copper bus bars for easy low impedance drive. Don't want to biwire if power drops to much ad rather put the full 75w threw standard wiring if I am losing
+1
Chris
+2
Bill
Vladimir said:abacus said:Covenanter said:davedotco said:cal said:Main reason my onkyo a9050 amplifier drops from 75w pair channel at 8ohm to 65w pair channel at 4ohm bizarre I no. But says thick copper bus bars for easy low impedance drive. Don't want to biwire if power drops to much ad rather put the full 75w threw standard wiring if I am losing
+1
Chris
+2
Bill
-1
Electrically it isn't the same. We removed the bi-wiring link plates and we doubled on audiophile speaker wire.
Vlad
Thompsonuxb said:You guys ever tried running 2 pairs of full range speakers of a single terminal?
I.e of side A for example and driving them hard?
Then run them of A and B see if there is any difference?
cal said:Thats why I wanted advise as the manual to amp says when using speakers A and B together make sure you use speakers with a impedance of 8ohm or higher. The amp has a ohm selecter switch 4-8. So stating using speakers at 8ohm when biwired using A/B together will drop them to 4ohm so it sees 4 speakers and my amplifier don't give as much power at 4ohm as it does at 8ohm. Do you think bi-wiring would be bad in my case vlad
