Octopo:
trevor79:See what you mean, to clarify I run the front Left & Right seperately bi amped, also I run them bi wired as well with Kimber 4TC to the mid/treble and QED SA to bass
You see, I had to read that twice to understand. Running cables from two different manufacturers is not bi-wiring. Oh Trev, you do confuse me...
Have a lay down and a cuppa.
Bi-wiring is simply running 2 sets of cables to a speaker, the benefits of which are a lower impedance through 2 cables rather than 1, better separation on the crossovers (providing you take the links out) leading to wider sound staging.
With that in mind I choose to run the better cable (Kimber 4TC) to the top crossovers to gain better clarity and detail in the Mids & Highs. The QED SA to the bass. Furthermore (to further confuse) on the 875AV amp equalizer settings (I run the front pairs on 'Full' speaker settings, not THX) I slopped back the bass response letting the SUB take over the heavy work.
This gives the Amp more headroom to use its power to supply effortless signal detail from 120hz upwards when driven on Pavarotti on full throttle!
Music is wonderfully detailed, dimensional with great presence (never a big wall of sound hitting you) and on good recordings the timber and texture is beautiful. With the various music settings on the 875 one can quickly find one that improves the poor recorded CD's than the totally revealing PL2 setting.
Yep Bi-wiring is a improvement, but your system needs to be up to scratch to get noticeable improvements out of it. Otherwise using 2 better quality / thicker cables in the 1st place will give similer results IMO.
