- Aug 10, 2019
- 2,556
- 4
- 0
I know, I know ground hog day again. I am reading a manual for the Onkyo 905 which should arrive soon. I thought I had a handle on bi amping/ bi wiring but now I am confused! I have the RS6 speakers and have wired the tweeters and woofers seperately (ending up with four wires- positives and negatives) for each speaker. I was then going to put the postives in one connection on the amp, negatives on the other and thought that was that. Is this correct? In the manual it says you should not connect more than one cable to each speaker connection otherwise it could damage the unit! It then goes onto to say for bi-amping I connect the front L/R terminal posts to the speakers tweeters terminals and the surround back L/R terminal posts to the front speakers woofers. Doing this will give an improved sound but means the system will be a 5.1 not 7.1.
Sorry if this sounds like a confused thread because I am confused!
Cheers for any help.
