Hi i'm looking at changing my nad c352 amp and upgrade to a roksan kandy k2 intergrated amp,i have got a nad c272 power amp with my c352,could i combine the c272 with the roksan k2 or is it best to bi amp with the same name
donlogan said:Hi i'm looking at changing my nad c352 amp and upgrade to a roksan kandy k2 intergrated amp,i have got a nad c272 power amp with my c352,could i combine the c272 with the roksan k2 or is it best to bi amp with the same name
donlogan said:Thanks for that,i am only a novice when it comes to equipment,i thought the roksan or another amp might be an upgrade option,but due to my lack of hifi knowledge i have to ask on forums like this
donlogan said:not obsessed with roksan k2 just interested,i only mix at home to record mixes for myself,i was interested in upgrading the amplifier budget of around a grand,i enjoy playing albums through it so its not all mixing,just trying to find out about an upgrade that will probably be my last upgrade
Bear in mind that DDC is obsessive about active setups and forget that most pro ones don't sound remotely good in the home, if all you do is want to listen to music. He's also wrong about NAD, which make fine gear, but I'd agree there's little to gain much going to Roksan if anything.donlogan said:Thanks that makes sense,appreciate your help
could you just go through how to set up what you said,mainly what connects where,i will look into getting some monitors too
altruistic.lemon said:Bear in mind that DDC is obsessive about active setups and forget that most pro ones don't sound remotely good in the home, if all you do is want to listen to music. He's also wrong about NAD, which make fine gear, but I'd agree there's little to gain much going to Roksan if anything.donlogan said:Thanks that makes sense,appreciate your help
If you want to be a DJ then sell the lot and do as DDC says, but if you want a decent hifi, don't. The choice is yours.
