Better sound from iPad using camera kit and USB DAC?
bay24
160
I have been reading that you can take the digital signal direct from the iPad using the USB conector from the camera kit. This means you can use a USB dac to improve sound quality (see link below).
http://www.benchmarkmedia.com/discuss/feedback/newsletter/2011/06/1/ipad-streams-high-resolution-audio-dac1
Does anyone have experience of doing this? If so can you use any USB dac like the fiio e10 or 17? Seems like a very good way to get high quality sound on the move?
If this works I think it would be that one extra feature that would let me justify getting one!!
John Duncan said:
No way I'm paying 25 quid to find out though...🙂
http://www.amazon.co.uk/gp/product/B005KG7BB0/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B003K1EYM6&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=14K2NVNSR0EFY7ATW1BF
I'm not sure it's shiny enough...
Well my £5.59 Shinnto adaptor works perfectly with my USB speakers. I am very happy. Thanks for the tip.
Also works fine with my cameras SD card.
Glad it's been of use! Still wondering if there are many portable DACs work in a similar way. There is a thread on headfi about it but it seems that often there s a need for an external power supply as the DACs drain too much power from the iPad and it is a bit inconsistent weather it works or not.
bay 24 is right. I've just tried my E7, and the iPad says it uses too much power, so it can't be used on the move I'm afraid.
I have excellent results using the camera kit into my CDQ's USB DAC using lossless files, I actually think it sounds better than my Squeezebox Touch using coax.
Thanks for confirming! I am not sure it is that simple though as I believe that it may work depending on which iOS you are using. I would quite like to know if the rpac works, seems like it could fit the bill!
Hi there,
Rpac does not work with my ipad2 sadly. It might work in conjunction with a separate powered USB hub but I was looking for a portable option.
Hi there,
Hi there,
wilsmusic said:
Hi there,
Thanks for the confirmation. That's a shame!
The Fiio E7 works fine, but you have to set USB CHG = OFF in the menu first. And it sounds great to me!
That's great, I wonder if the e10 or e17 work as well?
